Old 09-27-2008, 07:09 PM   #9 (permalink)
lotusforsale
lotusforsale's Avatar
Images: 8
Originally Posted by ZeeBest001 View Post
I got it last week and love it so much!!!!!!! I have been waiting for the perfect one for 6 months. This one was the perfect price and perfect everything!
Since owning it, I have a few questions which I am sure is answered else where.
1) What Gas is recommended for this vehicle? I filled it up for the first time using the most expensive octane, is this recommened? I believe it is called 92?
2) What oil weight and brand? I have heard on here that you only need to change it every 7500, should I change it every 3k?
3) What tire pressure and should I use nitrogen instead of air?
4) From reading you should not jump in it while putting your weight on the windshield. Is the windshield roll bar safe?
5) What is the recommend speed per gear in normal driving conditions. Currently in 2nd I shift to third around 30. 4th to 5th around 50 and 5th to 6th around 65.
Thanks everyone for any input!
Take your eyes off the speedo and put it on the tachometer. Shift according to engine revs, not road speed.
Why would you use nitrogen in your tires? WHERE would you get nitrogen?
For tire pressures, oil, service intervals et al follow manufacturers specs. Change according to your usage (ex. track use may require different tire pressures and service needs).
lotusforsale is offline   Reply With Quote
