Old 09-28-2008, 07:55 AM   #5 (permalink)
fzust
2009 XP National Champion
fzust's Avatar
Originally Posted by thegoat View Post
How long does it take to remove the rear clam on the exige, and would you remove it again if you were doing the install again?
Also, are there any fitment issues when replacing it? I am afraid that I will create a new squeak after removing and replacing the clam because it not would be perfectly aligned to factory specs or something like that (yes, this is a question that comes from never having removed a rear clam).
fzust, thanks for setting up this thread.
Ultimately the rear clam sits on shims in the back that are taped in place. It is pretty straightforward to re-align. I think on an exige, your life will be alot easier to install with clam removed.
