Old 09-28-2008, 08:42 AM   #6 (permalink)
mpsalm
BANNED
Originally Posted by thegoat View Post
How long does it take to remove the rear clam on the exige, and would you remove it again if you were doing the install again?
Also, are there any fitment issues when replacing it? I am afraid that I will create a new squeak after removing and replacing the clam because it not would be perfectly aligned to factory specs or something like that (yes, this is a question that comes from never having removed a rear clam).
fzust, thanks for setting up this thread.
Yeah I would def remove it again. It would be much faster the 2nd time. It's not very hard, a little time consuming. But you should be able to get it off in a few hours. Super easy to realign once removed. It sort of only goes on in one place... No new squeaks from the car and a few old ones are gone now. Hope that helps!
Good Luck!
mpsalm is offline   Reply With Quote
