Old 09-29-2008, 08:36 PM   #17 (permalink)
fzust
2009 XP National Champion
fzust's Avatar
Originally Posted by stinkyonion View Post
Then for the Moroso oil pan (also special discount right now on lotustalk $485 delivered) I just need some form of gasket goo like Hondabond and everything for a oil change (6 quarts synthetic 5w40, filter, oil plug gasket, teflon tape).
No other projects to be done at same time I take it. ( I really want a new intake and increased flow exhaust but it messes up the ecu program as I understand it.)
You may need more than 6 quarts with the Moroso pan. Make sure you check it and don't run it low.
You are correct about the intake. Cat back exhaust is no problem.
