Originally Posted by kestrel74
Mr C, let me begin by saying the bracket is outstanding !! Beautiful workmanship !..........BUT........after knocking mine off no less than 10 times, I decided I needed another mounting solution. I went out and bought some 1/8 " short wall anchors ( for 3/8 in drywall )....I cut the nibs off ( that would normally dig in to the drywall ) and put 4 flat washers against the part that would normally sit on top of the drywall. PERFECT !! creates a very solid mount. Thanks again !!
Sorry folks, I was out of town for a week and need to catch up now...
Kestrel74, you knocked your's off 10 times
Something seems to be very wrong, and I doubt that you installed it correctly
There would be NO WAY to knock it off without breaking the fiberglass unless you didn't install it right.
Imagine that the washer in this picture is the firewall with the Wellnut installed:
And this is what it looks like behind the firewall once you install and tighten the bolt:
Note how the Wellnut buldges behing the firewall!
Make sure you have it all installed correctly and you shouldn't have any issues with the bracket coming loose.
Let me know how it works out for you.
