Originally Posted by kestrel74
Don't get me wrong...still a satisfied customer !!......  Yep, I know how wellnuts work.... but, didn't work on mine... I have a steel washer in back of the fiberglass also.... I put the wall anchors in back of the steel washer.....works fine..
I just wonder how the entire bracket can fall off when the wellnuts are installed correctly
I thought you either insalled them backwards, or the holes in the firewall on your car are bigger than they are normally...
The steel washer behind the fiberglass also sounds strange...
There should only be the big black plastic cover which has the interior light and the speakers in it, and behind that is the fiberglass firewall. I have no clue how one would even get washers behind that fiberglass...
