Old 09-30-2008, 06:58 PM   #2 (permalink)
British_Marques
Elise...Best Daily Driver
British_Marques's Avatar
Okay, What you need to do is take a 20amp fuse with you as you poke your head upside down in the passenger seat and your feet hanging on top of the bow cover at the top of your car. look under the dash, you will find a triple block of 20a fuses and more than likely the center fuse is blown. simply pull it and replace with the new one and you should be fine. There are two set of those fuses under there. This is where they are located for the HVAC system. You should be fine except for the crick in your neck from standing on your head.
2005 Elise, Starlight Black/Red, Modified tilting clam, driving lamps, LED Tail lamp set, hybrid longtail/ and hardtop, Exige rear wing, radio delete, air bag delete, Custom Leather & Alcantra binacle, UK steering wheel, HVAC controller relocated, UK ECU, Carbon mirrors side mirrors, Zoom carbon rear view mirror, and Cup Wheels & Tires.
British_Marques is offline   Reply With Quote
