Old 09-30-2008, 06:34 PM   #101 (permalink)
elise/europa
elise/europa's Avatar
I found the source of trouble causing that I was not able to see online all gauges (or channel): my laptop. I still don't know exactly why. I just took a old laptop with direct RS232, and I was able to see the gauge.
With the possibility to see all channel, I was able to adjust the TPS, very important to control the idle. And now the idle is not so bad.
Still had difficulty with the start up, but my batterie is on charge. I saw that when I was cranking the engine, with a very low power into the battery, I lost the calibration of the TPS with the computer on-line...
Tomorrow I will go to a tuner to test more, and build one open loop map (for track), and based on that, I will build the close loop program for street (at the beginning).
The program is very easy, but I think it should be very nice to have a specific place to program the start mode, like the idle. It still not clear what the ECU is taking as parameter during cranking, like spark timing, crankng pulse (on fuel menu, and not adjustable based on air temperature). It is my major stress at the moment with the EFI, I am using my car on a large band of temperature (-10C to 35C), and no specific cranking menu will maybe not help me.
Elise 2006, white, BOE/EFI
Europa 1969, green, H22A, 194 whp, 1550#
CONFIGTECH.ca / Solidworks
elise/europa is offline   Reply With Quote
