Old 10-02-2008, 09:07 AM   #95 (permalink)
MaineLotus
2zz parts scattered about
MaineLotus's Avatar
Hi Phil,
Thanks! The Dash and DL1 wiring is almost done. I'd like to tap into the existing oil pressure sensor located on the sandwich plate. Do you see any problems with that? I did buy the DL-1, my goal is to log everything possible - boost, temps, speed, RPM, fuel pressure, boost temps (pre/post chargecooler), H20 temps, AFR, etc. It's a bit of work setting all this up, but hopefully will be worthwhile.
I did see the RaceTech sensors, they are pricey. Is the OEM oil sensor not the correct type? Not familiar with the sensor types out there.
How did you pick up RPM? I have a MSD 8918, which I think will work.
Regard,
John
My car is modified.
MaineLotus is online now   Reply With Quote
