Old 10-02-2008, 10:01 AM   #15 (permalink)
bobbythejudge
'73 Europa Headlights
After reading your comments I can see now why when we tried using a jumper wire connection it would not work. After taking out the headlight, we just twisted the 2 wires together and capped them and the headlight works just fine. As I am doing this I noticed the panel or dash lights are not bright either and am tracing the grounds for the reason why. Before this I had not tried them and that will be the next fix along with checking out the fan for the compartment, it seems to be a little weak. Thanks again for all of you for the advice, Bobby
bobbythejudge is offline   Reply With Quote
