Hi Charlie,
Thanks for your quick reply...sorry for my delay, I was travelling.
OK, I understand not to drive the car part converted and that your re-flash is not BWR bespoke, I'm OK with that.
However my "Dubai Special" settings are important, hence my interest in your reflash rather than PES. To go a bit deeper regards your reply :
1) KPH Speedo : Although I have a Frederal spec. car / ECU, would the refash convert to MPH, which I don't want? Aren't Federal cars also sold in Canada, where they also have KPH speedos?
2) Regards the ACU, the wide open throttle is probably more important than the raised limit from 6000 to 7000 rpm (but I'd like to keep both
). Asking Lotus to re apply this customisation is not an option. I realise you'd need my ECU 1st, however is the customisation cost completely open ended... in your experience will the cost (beyond the standard $600 reflash) be an additional $100 or $1000....
Thanks for your reply
Cheers
Sean
