They are body spacers that sit underneath the bolts that hold the rear shell to the sides. Hard to explain, but I'm sure you remember those two bolts (per side). They're designed to space the body out for proper outer panel alignment. I used some Hylomar to "stick" them in place on the panels while replacing the bolts.
Originally Posted by rstutts
3. When I lifted the clam off, 2 sorta u shaped shims fell out. One on each side. Does anyone know where these are suppose to go?
Rick
2005 Lotus Elise (Type 25 clone, LSS, Touring, Supercharged)
1970 Austin Mini Cooper, 1971 Series IIA 88" Land Rover, 1999 Land Rover Range Rover 4.6 HSE Callaway #071
