Originally Posted by Smoky
Are these brackets available for purchase? I would also like to relocate my Kenwood Amp/Sub to the passenger side and regain full fwd/rwd motion of the driver seat adjustment.
Julius: How much clearance do you now have between the backside of the passenger seat and the rear wall?
Thx
The depth of the space behind the passenger seat depends on where you measure it. My amp is 38mm (1.5"") thick and is mounted with the long axis horizontal and uses the entire width behind the seat. An amp 2" thick would probably fit that way.
There is a recessed space in the center of the seat (easier to see is you look at the driver's side) and if your amp would fit there your would probably have 2.5" of depth available.
All I can say for sure is that I have 3/4" more depth behind the seat than before. I mailed the seat brackets to Tespirt and he made the inserts for me. The inserts can be removed and the seat returned to stock position.
My set of inserts might not fit your car. Tespirt said previously he would consider making other inserts for folks but you would have to get him your seat brackets. Probably best you contact him directly if interested.
