Old 10-13-2008, 10:42 AM   #138 (permalink)
Whiskey
Love is More
Whiskey's Avatar
Originally Posted by rstutts View Post
I got the s/c attached last night. I think the biggest problem I am having is the wiring. The new extention wiring for the alternator seems to be a little short. It reaches but there is not a whole lot excess length. I am heading back out there to do another 15 - 20 numbers!
I had the same problem, so be careful with your wiring. The alternator cable should not be too tight. The engine moved enough that it pulled/sheared the wires going into the alternator. I had to solder a wire into the plug and extend and redo the other wires. Take a look at the picture in the instruction manual again. I didn't route mine properly the first time and ended up on the side of the road. Luckily, only a half-mile from my house and with a friend available for a ride.
The shear didn't appear for a few hundred miles. You will know that this wire is an issue if you notice your lights dimming and maybe a flickering MIL due to the slight short that occurred before a full sever of the wire.
Check the routing of your alternator's wiring and make sure it's exaclty as the picture displays. I haven't had the wiring problem since the correction.
Will
WTB: Elise Hardtop with Hardware - Storm Ti. (Color Code B121) Please send PM
Elise: My process of adding exige side scoops (+ Front Mesh)
| 2005 Lotus Elise : Sport Pack : Biscuit Touring Pack : Storm Ti | BWR Supercharger | Exige Side ducts and front mesh | LETSLA Short Shifter (ordered) |
Whiskey is offline   Reply With Quote
