Thread: Antenna again
Old 10-13-2008, 04:53 PM   #12 (permalink)
Yellow Peril
Yellow Peril's Avatar
Originally Posted by TimMullen View Post
A problem with antennas on a fiberglass bodied car is - well - the fiberglass.
The typical car antenna uses the metal body of the car as it's "ground plane" and a fiberglass body doesn't work that way. A typical antenna has the center of the antenna connected to the center wire in the antenna cable. The shielding on the cable is connected to ground where the antenna is mounted to the metal body of the car.
In the case of the Elise, we don't have that grounding.
The cure is to install an antenna that doesn't need the ground plane - they make antennas specifically for boats that don't need one, and some of the "dipole" antennas (I suspect that what we have from the factory, although I've never checked into it) - an antenna that typically has two wires branching out in two directions (they make simple ones to attach to your radio at home).
When I installed a radio in my Elan, I had to come up with an antenna. The Elan has a metal rod that connects the top and bottom of the center of the windshield (holds things together). I ran the antenna wire to this rod. It didn't work very well, until I connected the shield to the sheet metal chassis (which provided the ground plane). I don't know what it would take on the Elise for a good antenna...
Tim is right on, the factory antenna is technically a dipole. A real dipole has two elements pointing opposite directions from the central connection point (ie: 180° from each other, forming a T shape) with a balun transformer in the middle for impedence matching. The Elise installation is a piece of coax with extensions of the center conductor and outer conductor as two element arms at probably more like 120° (a Y shape), each element extending from about where the lotus badge is towards the a-pillar, one on each side (kind of like in the attached) all taped to the underside of the clam. This less-than-ideal structure compounded with it all being just direcly created from the coax wire (no balun etc.) makes for a poor antenna, but right on par with the $hitty audio system. I call that optimal engineering and perfectly aligned with what the Elise is all about...
Yellow Peril is offline   Reply With Quote
