Old 10-15-2008, 08:06 AM   #173 (permalink)
fzust
2009 XP National Champion
fzust's Avatar
Originally Posted by srwhitman View Post
Got my car back today from ForceFed. They did an awesome job. I am trying to baby it for the first 100 miles (now Fred says "few hundred"). I am up to 50 miles or so but babying it is hard. I am a little concerned about this MAS issue but since I didn't do the install, I don't know where to look for it much less how to verify its reading. Any help would be appreciated.
Scott
From post #106(bears repeating...)
Additionally, we've done extensive testing and I want to point out something we've discovered. It is CRITICAL that anyone installing ANY supercharger kit inspect & test and/or replace their mass-air sensor element. We've seen that the mass air sensor element can get very dirty(remember in the lotus much dirtier air hits the intake than a car with a front intake.) and this dirt will cause the mass-air sensor to read low(Its a fairly linear change). Aftermarket intakes, higher mileage cars, and cars operated in dustier or dirtier conditions are even more prone to this.
This will cause the ECU to think more air is entering the engine than reality you will have a potentially dangerous lean condition!
You can test the mass-air sensor with a scan tool by having someone monitoring the mass-air sensor while you drive WOT in second gear. You should see ~5grams/sec at idle and 225-230grams/sec at above 8200rpms. If you see much less than this you should replace your mass-air sensor element. These new mass-air elements may not survive harsh chemical cleaning and should just be replaced.
Since this time, others have apparently successfully cleaned the MAF. I would still recommending to replace it to be safe.
