Originally Posted by jim-clayton
Hey Dave,
Yes I had it installed. The "download data" has worked a couple of times.
The progress bar comes up and quits have way through. I forget the exact
error message. I'll get back to you on that.
What setting do you use to start the data logging?
The logger is constantly collecting data starting right at engine crank. Make sure you start the download after shutting the motor down, then turn the key back to acc position with motor off. Hit Ctrl+D and the file downloads to the C:\Power to Win\Data directory.
Check also your logging table (under the config tab). Turn off any channels you really don't plan to use. There are also several enabled by default that aren't even utilized by the 2ZZ, so disable them by double-clicking and set sample to 'off.' This could be part of the problem. Also, reduce all the sample rates of the channels that aren't critical to save memory and increase logging time. (100Hz uses the most memory...and fast).
