Also, consider dumping that aluminum foil heat shield bullsh*t, clean the entire firewall and us the gold heat shield from C&R radiators or Pegasus. It's expensive, but better thermal properties and weighs probably 1/10th of the original. Besides, your exhaust is no longer facing the firewall with this conversion.
Furthermore, be cautious of your AN hose assembly. You want to avoid those little sections of hose between the AN fittings. Such short lengths are often subject to failure. If there's another way around this plumbing problem, it should be pursued.
Also, is the check valve hiding underneath the frame between the electric solenoid and your 90 degree -10? If not, there really needs to be one there. I'll explain the theory if anyone cares....
Mike Cudahy
President
Prototype Composites
(414) 354-5144
