Finished the install of my
RacePak IQ3 Dash today. Sensors hooked up to it are:
GPS Speed
Lat G
Accel G
Vertical G
Lap Timer (Best Lap)
Fuel Level
Gear
Oil Pressure
Oil Temp
Water Temp Intake
Water Temp OEM
Post IC Air Temp
EGT (Cylinder #4)
Boost
A/F Ratio (Wideband)
Odometer
As you can see in pic, need to find out why my Oil Pressure is not reading correct - 168 psi is a little high
Think I may have assigned two sensors to the same channel.
Now I can finally put the roof back on the car...
Rob.
