Typically I don't prefer to use a orbital to remove a product, as hand removal is more effective in the smaller spots and is generally more safe. Griots also sells an attachment for your buffer to clay with. That sounds terrible to me! If you like machine removal though, then do what you like.
The key to getting any wax to remove quickly and with little effort is to apply it as thin as possible. For Zaino I put it on so thin that I can barely see it head one and have to shift around a bit to see the application. Effort increases quite a bit with thickness. P21S is a wipe on, wipe off product which aids removal. Still, it can be fussy if you really slop it on, but you don't have to be that carefull with it. In any case, go thin! It will at the very least save product.
