Originally Posted by slaughtr
An update on my car...
After some track related car repairs I finally went out and finished (for now) the tune on my car. With a base map from Kris and some excellent advice from Phil, my mechanic and I hooked it up and went at it. I installed a wideband O2 sensor from Innovate as well as A/F ratio and boost gauges. The gauges went into the aluminum center stack gauge pod from Blackwatch racing which I have to say looks excellent.
My base tune was pretty good, but had some areas with too much fuel, for safety sake. The whole thing only took about an hour and a half, making small adjustments in the air fuel ratio at idle, cruise and full throttle. We added a bit of timing too.
The car runs better than it ever has. I'm really happy. We may have taken a bit too much fuel out at cold start-up, but we only got one shot at that so it will have to wait. Other than that, the idle is rock steady, cruises without any hiccups and is scary fast.
Thanks Kris and Phil!
Ronnie
Very glad to see you guys are happy with the results. Good job!
Kris
