Old 11-13-2008, 08:48 AM   #40 (permalink)
Mag
Madness...
Mag's Avatar
Just installed the RLS WI kit with RLS IC/pipes, roof scoop unfettled, dual SPAL push fans inside shroud. Using 100% distilled water, no meth.
posted non WI data on a "flow" thread in this forum. If interested in how data is being aquired and for basis of comparison, please see that post. Some initial results.
75 °F / 24 °C
Humidity: 61%
2 pulls out of 6 I usually do. max temp went to about pre IC 85~90C, IAT remained at a consistant 40~43C with WI on and 57C+ off, IC fans on whole time. That's a minimal 15C, and WI is supposed to be less effective in cooler weather. I bet if I did 6 pulls it difference would have increased… Will go to the track in one week. Aim to do some actual data logs then.
Normal milld driving saw low to mid 30C (note outside ambient temp is 24C). from low 40s to mid 30s the IAT dropped really fast with the WI, you can see the IAT go down soon as the pedal to the metal is released.
91 NSX, 3.2L ITB (in progress)
93 Supra TT
95 BCNR33 GTR, 2.8L TT
00 s2000, 2.2L
08 Exige S240
Mag is offline   Reply With Quote
