Old 11-16-2008, 11:47 AM   #44 (permalink)
jamie
jamie's Avatar
Interesting seeing another take on the layout for a SC/IC set-up two questions for you though - are you not worried about the relative weight above the engine (it must raise the centre of gravity) also having the oil & IC radiator feeding from the roof scoop are you sure firstly you will get a decent enough airflow and secondly how about heat sink from the engine?
Most of the solutions I have seen are either IC radiator up front twined with the main radiator or in a side scoop.
jamie is offline   Reply With Quote
