there's no way you'll be able to run that setup on 440cc injectors, you'll max out well before peak rpm, switching to the 550cc's will help, but you'll still need to upgrade the fuel delivery either with a swirl pot or higher volume fuel pump to make it into a kit , with the stock pump on the 550s, you still be well into the 90s
even though you're making less power than the mp62's with the 3.0 pulleys, you'll still be out of fuel in the 6000-7000 rpm range, especially with the higher boost.
