Old 11-20-2008, 08:39 PM   #155 (permalink)
fzust
2009 XP National Champion
fzust's Avatar
Originally Posted by charliex View Post
rob, the injectors are running at 100% DC and the AFR's are going above 13, what does that tell you ? 440s and 550s, with only a minor change in the RPM they max out.
i think vf are planning something.
Charlie,
I could be mistaken, but I am pretty sure all the ForcedFed cars including the 340 and 380 used the stock pump. Maybe Casey will chime in. I wonder if the car you took the data on had a fuel pump on its way out. That's what happened to my car while on the dyno with Kris after a year or so on the 750ccs. when we pulled that pump out of the tank after, it would make stock pressure but deliver zero volume. Yanked it for another new stocker and it was fine. While we had the tank out we made the swirl tank etc etc.
