Old 11-21-2008, 11:45 PM   #12 (permalink)
redguitar
Originally Posted by iwantanelise View Post
Definitely wax the starshield. To prevent wax build-up along the starshield edges, use 3M blue painter's tape to cover the starshield edge before waxing. This way, the wax build-up will stick out without an edge to press-up against once the tape is removed during wax removal.
Thanks for the pro advice, but can you please clarify how the tape is applied? If it goes along the edge, then there will be an "unwaxed band" around the perimeter. I'm sure I just don't understand your technique correctly, especially when you add that tedious hand-removal is needed ---- even with the tape? Thanks.
redguitar is offline   Reply With Quote
