Old 11-28-2008, 10:01 AM   #175 (permalink)
Illumiloti
(Formerly PESTODUDE)
Illumiloti's Avatar
That said, I'll build a kit to mount to the S manifolds as well. However remember that the setup will all ready about max out the stock pistons w/o an IC. To add an IC and bump the boost up will push you further into that glass ceiling. So, adding an IC to the TVS system for Elise or NA Exige guys, in particular, would only really be a substantial benefit if you swapped the pistons for lower compression units and then go for a 300+ whp monster...
Phil
I (and I'm sure others) would go for this kit for my Exige S. I have a water to air IC so that would allow me the option of pushing the envelope even further at at later date.
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune.
Illumiloti is offline   Reply With Quote
