Old 12-01-2008, 08:52 PM   #6 (permalink)
wf758
CRUS8R
wf758's Avatar
Originally Posted by Randy Chase View Post
Make sure you are making a good connection. Where on the frame is the ground connection? Have you tried connecting to the Exige's battery terminals directly?
Yes, was directly on battery terminals on Exige
tat tat means what? Is it a clicking noise?
Hard to describe (I feel like one of those commercials where you are describing the indescribable!) Whole car goes off and on in a series of tats as I hold down Start Button. That means instrument cluster lights flash with the tats and it sounds like it wants to roll the engine over, but just won't quite do so.
Why was the battery dead to start with? What made you think it was dead?
Sorry...another post. I either created a short when hardwiring my V1...or I left the light on after installing the V1 bracket. In any event, after working on the electrical system, i let the car sit for three weeks. Tried to fire it up last night and all was dead. Since car battery charged a little on the Tahoe, interior lights now come on. So i'm fairly certain battery is dead. Not quite sure of the cause.
Have you taken a peek at the primary wiring to make sure the connections are tight. Not uncommon to have the battery connections come loose.
No, thanks...I was just researching and saw that was an issue. I'll check it out.
Will
2007 Lotus Exige S - Tow Eye, Boomerang, Sector 111 re-Enforcer, Stan's fix, Alex's 1/4 Turn Kit, Hardwired V1, Rearview Mirror Delete, Saikou Michi Catch Cans, Odyssey PC680 & Sector 111 Bracket, Bane's Stealth Bulbs, more to come...
wf758 is offline   Reply With Quote
