Originally Posted by ggelise
Charge coolers are what the doctor ordered...what a difference. Congrats on hitting those numbers. The car must be insane. If you do a You Tube clip or have some pics, post them up so we can take a look. With that range of power are you going to upgrade the clutch etc.? Thanks for sharing this.
Mike that is hilarious....what a classic film
We are thinking of doing the rear deck in foil to maintain a stable pressure in the accusump. What do you think? Will probably do a heat shield for the IC barrel in foil also. We are listening, it just takes time to get things ordered. What is up with your customer's car in Australia? Looks like he is pulling out all the stops. Heavily modded s1's Exiges are selling for big bucks over there ...I can only imagine what this guy has in this thing. I lived over there as a kid and remember how expensive it was to bring anything down to the bottom of the earth. What an awesome country!
I picket the car up in the wet so did not really experience anything more than wheel spin
But about 40 miles down the road the SC shaft sheared off. The SC has had a hard life already and there is a new uprated version which i will get fitted. So I wont see the car till Jan now
Here is the offending item
There were stress fractures in the metal that had started to Oxygenate so it was a long time coming.
Clutch will get replaced with a uprated version when it fails
Will post some Vid at the end of Jan
Did you have a think about a dry sump for your car?
