Jumpers are hooked up to my Tahoe, with Negative on Tahoe run to frame.
First make sure that the connection points are clean and tight. Also you could try hooking directly to the battery, you could be on a questionable spot on the Tahoe frame. The tat,tat,tat sounds like it is clost to starting but just not quite there so giving it the best possible connections might help. Also a battery tender might not be a bad idea if you leave it for extended periods.
