As for the possibility that the V1 is wired to the wrong power source (the radio "always live" instead of the switched circuit), it's fairly easy to test (after the battery is re-charged). Turn on the key. The V1 should be turned on. Then turn off and remove the key, and the V1 should turn off. If it remains powered on, then you have it connected to the wrong wire and need to switch it to the other.
Got the battery charged and the car started again. I tried the V1 and it definitely turns off when I turn the car off and remove the key. (So, I think my wiring handy work was ok). Usually, I pull the key out (to shut everything down) and then push it back in and leave it in the garage. I have a feeling I forgot to pull it out last time and that is what led to the power drain. Anyway.........thanks for all the help.
By the way, see Post 41 of my other thread on Jump Starting. If anyone has any ideas as to what would have caused an Engine Malfunction Indicator Light, I'd appreciate your insight.
Will
Will
2007 Lotus Exige S - Tow Eye, Boomerang, Sector 111 re-Enforcer, Stan's fix, Alex's 1/4 Turn Kit, Hardwired V1, Rearview Mirror Delete, Saikou Michi Catch Cans, Odyssey PC680 & Sector 111 Bracket, Bane's Stealth Bulbs, more to come...
