Kris suggested that it could be a result of the stock ECU going into limp mode and triggering the AC to stay on somehow. I tend to agree as my AC will work fine so long as I don't exceed 4K rpm -- which seems to be the trigger rpm that put the stock ECU into Limp mode and hence AC get stuck ON and as do my radiator fans.
I disconnected the AC clutch wire until I can find a good solution (fortunately hot days are 5 months away).
