I assume you're talking about connecting the BT pig-tail so it can be easily plugged in.
Find a bolt that fits the hole (should be threaded as mine is) in the picture below. Attach the negative (black) terminal here, and the positive (red) to the battery positive terminal. This works well because the pigtail can then be fed through the louvers for easy plug-in.
