Originally Posted by RoadDad
foosh,
How long is your "pigtail" connector? There is no way that my connector would go from the engine bay through the divider between the bay and the boot to get to the battery. It's just not long enough.
Mine is connected directly to the battery terminals, fed out the back of the battery cover and hangs along the front of the cover in the boot. No fires or blowing up so far when I connect it.
Sure it is, just split the red and black sides of the cable by pulling them apart, until you have enough lead. My cable is the std. one that came with the std. $19 BT. However, connecting to the battery is fine in 99.999999% of cases. Attaching to a ground away from the battery is just an added precaution.
