Old 12-10-2008, 11:30 PM   #26 (permalink)
Arno
Nerd on wheels
Arno's Avatar
Originally Posted by Chili Red View Post
Yes please post pictures if you have them.. I may just try this if its not to expensive. I can for sure tell if it works or not in one hot lap. I may also try pulling the ABS fuse to see if that helps any.
Then before you invest any time and/or monney I'd first disconnect one of the front wheel sesnors. Just disconnect the plug and tie the cable away a little.
This will disable the ABS, but keep everything else operating normally.
Still have the problem? Possible vacuum issue
Problem gone? ABS is causing your problems.
Simple..
Bye, Arno.
My Elise + K20A2 + TODA bits == Heaven!
Arno is offline   Reply With Quote
