Old 12-22-2008, 03:00 PM   #13 (permalink)
Trevor
Trevor's Avatar
Originally Posted by khamai View Post
Trevor,
I assume you're not trying to cover the wheels/tires. A 190mm body should fit much like the truck body shown above. You may have to open up the wheel openings to accomodate the suspension travel.
You might try doing some research on the Tower site and get some chassis dimensions. The HPI bodies fit just about any RC road chassis.
Typical BODY-
Length: 17.5" (445mm)
Width: 7.5" (190mm)
Height: 5" (126mm)
Cheers,
Kiyoshi
I under stand what you are saying but still dont think it will fit. Because of the lenght of the shock towers. The shock towers on my truck are much farther apart then most 1/10 scale trucks. You can also look at this another way. The rustler(my old truck 1/10 scale) can not use a T-MAXX body because it is way to big for the truck. So you can not use a rustler body on a T-MAXX because it is to small. The trucks are the same scale but the specs are different. Also the length of my trucks body is 20 inches.
Trevor
Trevor is offline   Reply With Quote
