Old 12-28-2008, 07:34 PM   #89 (permalink)
Dapcius
There are several reasons why I have changed headlights . Needless to say the original ones were crushed in accident . After changing shape of clam the original headlights follow completely diferent lines .there are only about 3 " of clearance where the top of headlight should have been between wheel and and fiberglass and im going to lower car by 1,25". there would be not enough clearance specialy when cornering . Im even going to put lower profile tires just to make sure it is not rubbing on bottom of clam . Another thing is the weight Lotus headlights are farely heavy guessing close to 5 lbs the ones im putting in around 1lbs for all 4 of them . At least it will compensate for all bondo im putting on it After all the only purpuse of this wehicle is track .
Dapcius is offline   Reply With Quote
