Old 01-06-2009, 11:18 AM   #21 (permalink)
SweetDaddyD
BANNED
SweetDaddyD's Avatar
Images: 2
Originally Posted by xxguitarist View Post
The 2nd stage slip solution is half rubbing alch, so it's quite volatile, and the vinyl won't even stick down until the slip is gone. I wouldn't worry about having fluid left under the vinyl.
If any application fluid (and 50% rubbing alch is too much- it should be 25% or use an actual commercial fluid) it will evaporate out in a few warm days. Just like how you often have a small bubble under the paint protection film when you pick the car up and once it gets some time in the sun it evaps out. Also alcohol evaps fast.
Newman- just makes sure he gives you cast vinyl. If you get calendared sign vinyl your installation will be twice as difficult. I wouldn't even try it with regular vinyl but then again I rarely even stock anything non high perf. since I don't like working with it and am generally doing car stuff anyway.
SweetDaddyD is offline   Reply With Quote
