Old 01-11-2009, 02:45 PM   #1 (permalink)
bbb
Fitting Exige Scoops on Elise
Hello all,
Need some opinions on whether this will work...
Basically i am trying to install the scoops without having to:
drill a hole in the body,
drill a hole in the fins,
remove the fins....
Referring to my pathetic drawing below, one way i was thinking was to have 3 x L shaped brackets which screw into the back of the scoop using the original mounting screws. The other half of the L bracket has a hole in it for the cable tie/s. The ties then wrap around the original fins.
To install it you would first tightly screw the L bracket to the scoops, then feed the cable tie around the fins and through the L bracket, then tighten the cable ties by accessing them from the behind the fins.
My concerns are....
Will the cable ties be strong enough?
Will the top front of the scoop be held into the body tight enough due to the cable tie running back to the fin??
So if this method is not ideal any other suggestions??
I noticed another member has made a bracket but I don't think it will work for me with fins still in place...
http://www.lotustalk.com/forums/f92/...-scoops-66875/
Thanks
Brendon
bbb is offline   Reply With Quote
