Old 01-26-2009, 01:04 PM   #10 (permalink)
TheViper
Alarmed & Dangerous
TheViper's Avatar
Do a "Load" test on the battery:
If the battery's state-of-charge is at 75% or higher, then load test the battery by :
Turn the headlights on high beam for five minutes,
DURING the load test, the voltage on a good battery will NOT drop below 9.7 volts with the electrolyte at 80 degrees F (26.7 degrees C). [If the electrolyte is above 80 degrees F, add .1 volt for every 10 degrees above 80 until you reach 100 degrees. If below 80 degrees F, subtract .1 volt for every 10 degrees until 40 degrees.] After the load is removed, wait five minutes and the battery should "bounce back" to the 50% state-of-charge level or above. If the battery drops below minimum test voltage, does not bounce back, or will not start the engine, then you should replace it. If the battery passes this test, you should recharge it to restore it to peak performance.
