Couple pictures of the aluminum brackets that hold the engine cover , will make another set of brackets that will hold difuser in place . Difuser is sanded and rivited but still held in place by 4x4. Aerocatch latches in front were a bit of challange , the area where they are mounted is not flat . there were almost 1/4" gaps in front and back . Had to heat them with torch and bend them to follow the body shape . Turned out pretty good.
Got everything bolted on , started on final bodywork . I want that bodywork to look perfect , and its taking a while .
