Originally Posted by TroyLotus
5-To change the throw you would just adjust where the rod end bearing attaches to the crossgate for 2nd-3rd, 4th-5th . You would change the location of the rod end bearing on the shift bellcrank lever to change the throw for 1st-2nd, 3rd-4th, 5th-6th. So you move the rod end bearing closer to the pivot point to increase the mechanical advantage and shorter then throw.
To be clear, moving the rod end bearing closer to the pivot point will DECREASE the mechanical advantage (of the shift lever over the transmission) and shorten the throw.
Think I want one of these kits.
xtn
