Old 02-08-2009, 11:39 AM   #13 (permalink)
Simba
2/3 hp to the paws.
Simba's Avatar
Originally Posted by lotuson74 View Post
I will do my best. Also please note, I said it will start to produce boost around 3200 (1psi or so) not reach full boost. Full boost will likely be closer to 4500 and it may require 8 or 9 psi - as long as the paramaters are acceptably within limits. My car will be minus its cat. as well, but I plan to dyno test with the cat too. I am certain of at least 290rwhp and aiming for 300. Time will tell.
Well, good luck with it. For what it's worth, I use a GT28RS on my car, and ~12 psi is good for about ~265whp. That's with some head work, and not entirely conservative AF and timing. To get into the 300's, I need ~16 psi and race gas, and that's really pushing one's luck at stock compression.
The GT28 series can spool well, but the compressor isn't nearly large enough to make 300 whp at such a low boost. As well, with a tiny turbine A/R, you're going to choke it at higher revs. I found a .63 to be about ideal.
Also, you'll want to bring your cam change point down into the 4,800-5,400 range, and that's not possible with a piggyback.
