Old 02-16-2009, 02:22 PM   #227 (permalink)
jayhillgolf
jayhillgolf's Avatar
[Service #13] January 30, 2009 - 26,579 miles
The guys at Mulholland Motorsport did wonderful job with my car. It was great to see Stephan (formerly with Lotus Beverly Hills) at Mulholland Motorsport!
Julio and Stephan replaced my tires (Toyo Proxes T1R), brake pads (OEM pads), oil change, and some minor works (rethreading a couple of holes for the undertray screws).
They also helped me to install the Sector 111 Boomerang Rear Tow Hook on the car.
Great service!!! Highly recommend them!
A couple of pictures of my happy Lotus after a day at Mulholland Motorsport.
All the services since new
[Warranty Service Items]
- ECU (replaced) - LBH
- catalyst/downpipe (replaced 2x) - LBH
- camshafts (replaced) - LBH
- O2 Sensors (replaced) - LBH
- fuel injectors and coil packs (replaced) - LBH
- exhaust (Stage-II cracks, replaced 4x) - SMC/LBH/LC
- wiring Harnesses - LBH
- front/right turn-signal housing (replaced) - LBH
- A/C relay (replaced) - LBH
[Warranty Accessory/Part Items]
- soft-top bars (not supplied by dealer) - SMC
- blower motor resistor kit (update) - LBH
[Undocumented-Warranty Items]
- front/right turn-signal bulb (replaced) - LBH
- loose handbrake lever (repaired) - LBH
- passenger-side window making wind-noise (repaired) - LBH
[Non-Warranty Items]
- oil changes w/ Mobil Delvac Synthetic 5W40 (@ around 1,000mi, 7,000mi, 12,000mi) - SMC
- oil changes w/ Havoline Synthetic 5W40 (@ around 17,000mi) - LBH
- oil changes w/ Havoline Synthetic 5W40 (@ around 22,000mi) - LC
- oil changes w/ Castrol Syntec Synthetic 5W40 (@ around 26,500mi) - MM
- rear tires Yokohama ADVAN A048 (replaced @ around 12,000mi, nail in tire and wear) - NE
- rear tires Yokohama ADVAN A048 (replaced @ around 17,000mi, nails in both tires) - LBH
- front & rear tires Toyo Proxes T1R (replaced @ around 26,500mi, nail in tire and wear) - MM
- front brake pads w/ OEM parts (replaced @ around 18,000mi) - LBH
- rear brake pads w/ OEM parts (replaced @ around 26,500) - MM
- "ECU Upgrade" with factory upgraded software (added then removed) - LBH (SSL)
- new front clam and clearbra (Star Shield) - SCC
[Accessories Added]
- Rear "Round" Lotus badge (Sector 111)
- Front Tow Hook (Sector 111)
- Rear Boomerang Tow Hook (Sector 111) - MM
- Lotus Cup/TRD airbox upgrade - LC
(*LC - Lotus Calabasas, *LBH - Lotus Beverly Hills, *SMC - Symbolic Motor Cars, *SSL -Silver Star Lotus, *NE - Newport European, *SCC - Specialty Car Craft), *MM - Mulholland Motorsport/Dent Works)
Wow.... I had a 79 P. 911 turbo that was always in the shop... I teach golf on the PGA Tour. Full swing, short game and mental game..
You must read this every day..
Patience is the ability to endure waiting, delay, or provocation without becoming annoyed or upset, or to persevere calmly when faced with difficulties. Your good..
jayhillgolf is offline   Reply With Quote
