Originally Posted by turbophil
oil pump, valves, springs, and pressure plate are all critters that break with higher revs if left in stock form. If the OP has got this stuff renewed with better bits, than have at it. CX is your guy for that...
Not that it matters a whole lot, but why are you interested in raising the revs? I've thought about doing it for a quick and dirty drag strip run. I figure 4th is only good to 112-114ish so being able to rev to 9000 or so would allow trap speeds to 120ish mph... outside of that, I can't think of anything else???
Best,
Phil
I'm looking at various ways to increase the power. It may be easier to boost things up but there are always consequences unless there is a total engineering solution.
