Old 03-15-2009, 06:17 PM   #4 (permalink)
Certified Lotus
Certified Lotus's Avatar
Originally Posted by apk919 View Post
Nice installation! How did you attach the brackets holding the ChaseCam and Traqmate? Did you have to drill/tap into the aluminum extrusion?
Also, is it necessary for the Traqmate GPS antenna to be outside the car? Given that the clam and roof are fiberglass, it would seem that the antenna could still be inside the car. After all, the stock location for the satellite radio antenna is in the instrument binnacle, and I've had my Garmin GPS under the roof and functioning perfectly...
I did tap into the aluminum extrusion for all brackets. Small holes well placed.
Regarding the antenna location, I spoke with lots of racers who had every kind of antenna install you could imagine (on many types of cars). Common comment was if the antenna is on the roof you won't loose the signal. Any other location had some type of signal problem somewhere on the track.
'07 Exige S,LSD,2bular Header,SportCat & GT3 Exhaust,Gotham Tune ECU, V2 Fuel Cell,BOE Surge Tank,MWR Fuel Rail,RLS Intercooler&Pipes,CircuitWorx Oil Pump Gears,Moroso oil pan, Accusump,Fidanza 3.2 Kevlar Clutch & Alum Flywheel,Nitron GT3,V2arms,AP Racing Brakes(315mm),SS Brake Lines,Prototype Composites CF Roof,ReVerie CF Front Splitter,diffuser & 1650MM Wing,RTD Brace, SSC Shift Cable, Lotus Racing M Mounts/High Perf.Air Box,Defi Gauges,RAC Monolite Wheels,Safecraft 5 Point Harness,Traqmate.
Certified Lotus is offline   Reply With Quote
