Stage 3 VF is same price as stage 2. The fuel pump price doesn't change, the price on the tune doesn't change, and all the pullies cost the same as well.
I'd be suprised if VF charges more for a stage3 vs a 2 but I guess that could happen. Just call Jermaine and ask if you need to verify.
Haven't looked at the sheet in a while, but why does the "estimated cost" for installing a fuel pump on a VF $100 more than a TVS? Also pricing is wrong for the stage2, it's listed
here for $6400.
Not sure what is up with your hp numbers either. If you are using the same formula for dropping the vf numbers down then any dyno's me and Matt do are worthless to you as the dynapak we use reads alot lower than the one VF uses at their shop.
