Originally Posted by robains
Excellent, thank you Kris!
Please do get into more details on the auto blip down shifts -- like what hardware is specifically needed.
Rob
- Auto-blip downshifts:
- Typically used with Sequential Gearbox
- Typical method uses a Strain Gauge Sensor on the gear lever (or micro-switch).
- Above can also apply to paddle shifters
- When the voltage is recognized by the ECU it uses this input to activate the calibrated throttle "blip" function
- The throttle blip calibration is defined by amoutn of throttle change and for time duration in ms before resuming to standard mode
- No-lift-shift
- This is also typically used with a Sequential Gearbox
- This also uses a Strain Gauge Sensor on the gear lever (or micro-switch)
- When the voltage is recognized by the ECU it uses this input to activate the engine cut.
- The No-Lift-Shift calibration is defined by the voltage range of the device and time duration in ms.
Kris
Motorsport Components and Expert Service. Complete Lotus maintenance, installations, track preparation and specialty services.
