Thread: ECU problem
Old 03-25-2009, 04:08 PM   #9 (permalink)
dereklburt
dereklburt's Avatar
Charlie, I could car less if I have a piggy back or not. Unless there is a benefit, I would rather not. Monkeywrench did away with part of the function of the Greedy Emanage after you programmed my computer but since it was only a base supercharged car program, I guess they tried to "tune" with the emanage to make it work for the turbo. If we could program the computer to take care of everything and get rid of the piggy back, that would be fine with me. I just want my car to run right and I haven't had any real luck as of yet.
The car as you know was a HASS turbo kit and it came with the Greedy Emanage and water injection. Now, the water injection has been removed and they rewired some things on the Emanage. If we could eliminate all that and get it running right without it, I would be more than happy. Charlie, you could have the emanage system in that case (if you wanted it).
Charlie, I know you had offered to tune my car and if I need to compensate you, I am prepared to do that. I know that when you offered, you mentioned tuning it but now we may be looking at more work to get it right. If the emanage needs to be removed and other things, I will pay. I just need to get it running right.
I just have so much into this car now and it is so frustrating not having it run right. Monkeywrench just told me initially that they would have you do a computer and everything would be right with it. Well, you can see where that has got me. All I can do is hope for the best at this point. I guess the car is back on the dyno today so I guess I will see. It apparently must be running at least. What do you think Charlie? Anybody else have any suggestions?
2006 Elise turbo- 355rwhp 278lb/ft rear wheel torque
dereklburt is offline   Reply With Quote
