Old 03-26-2009, 08:00 PM   #11 (permalink)
dstevens
2zz exorcism complete
dstevens's Avatar
Images: 4
I think you're making the H pattern no lift shift more complicated than it needs to be. For upshifting, it is very simple. Cut the engine output while the clutch is down. To shift, you just keep your throttle wide open and operate the clutch and shifter as per normal. It works very smoothly. No timer used, no dog gears needed. For downshifting, blip the throttle manually (well, there's no other way with a manual throttle body).
-2ZZ +K24 +150hp +118tq +7mpg +LSD -30lbs -CoG +F.bias
dstevens is offline   Reply With Quote
